Need help on buying a prebuilt pc
GetOffline
8
Hi, I am thinking about buying my first pc and I would like some advice and assistance. I am aware that building is cheaper,but I am not comfortable building my first pc and would rather purchase one. This is a pc I configured and was wondering if these components and parts can work for gaming and work. I'm aiming for a budget gaming pc and my budget is around $900. I am purchasing from cyberpowerpc. I was also wondering is ultra care packaging and professional wiring worth the extra $19. Thank you in advance
Gaming Chasis: Raidmax Trinity Mid-Tower Gaming Case w/ USB 3.0, & Side-Panel Window (Black Color)
Extra Case Fans: Default case fans
CPU: AMD FX-8320 3.50 GHz Eight-Core AM3+ CPU 6MB L2 Cache & Turbo Core Technology
Venom Boost Fast And Efficient Factory Overclocking: No Overclocking
CPU / Processor Cooling Fan: Asetek 550LC 120mm Liquid Cooling CPU Cooler - Extreme Cooling Performance (Dual Standard 120MM Fans (Push-Pull))
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: GIGABYTE 970A-DS3P AMD 970 ATX w/ Ultra Durable 4 Classic, On/Off Charge, GbLAN, 2 PCIe x16, 3 PCIe x1, 2 PCI
RAM / System Memory: 8GB (4GBx2) DDR3/2133MHz Dual Channel Memory (ADATA XPG V3)
AMD Radeon RAMDisk: None
Video Card: AMD Radeon R9 280 3GB GDDR5 PCIe 3.0 x16 Video Card (Single Card)
Freebies: FREE! AMD Never Settle Space GOLD (3 Games)
Power Supply: 550 Watts - Enermax Revolution87+ ERV550AWT-G 80 plus Gold Certified Power Supply
Hard Drive: 1TB Western Digital Caviar Blue SATA-III 6.0Gb/s 7200 RPM HDD (Single Drive)
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
LCD Monitor: 20" Widescreen 1600x900 Scretpre E205W-1600 LED Gaming Monitor (Single Monitor)
Internal Network Card: Onboard Gigabit LAN Network
Keyboard: AZZA Delta Gaming Keyboard w/ Anti-Ghosting & red backlight
Mouse: AZZA Alpha 1600 DPI Gaming Mouse
External Wireless Network Card: TP-LINK TL-WN727N 802.11b/g/n USB 150Mbps Wireless USB Adapter
Yes, that is a decent gamer. Should be able to play at max/near max settings at any game @ 1600x900. The monitor is kinda tiny, but if 20" is good for you, go with it. After spending that much for the PC, it would seem a bit foolish to hold back on $19 for a better wiring job. Proper cable maintenance is important to allow for good air flow throughout the case. I'm not sure what "ultra-care" pkg. is. I would think they would pkg the system good just to avoid unnecessary returns.
I can't find the Trinity case on Raidmax's site: http://www.raidmax.com/chassis.html
But if it is this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146015
...it only comes with tiny 80mm fans side and rear. Better would be a 120mm front...
...it only comes with tiny 80mm fans side and rear. Better would be a 120mm front and 120mm rear.
