Need help on buying motherboard!!
This board support 7th gen with certain BIOS version. If the version installed is lower, it will not start with 7th gen CPU at all. If seller mentioned this, it would mean that current BIOS installed on board is lower version, so it would not work with 7100 unless you update it yourself (but you need 6th gen CPU for that).
MERGED QUESTION
Question from davidtmason2001 : "Motherboard buying assistance"
yes
MERGED QUESTION
Question from davidtmason2001 : "Question on motherboard bios"
*Ah right
