Need help on changing my ram speeds
TheAspiringNerd
61
So this is my first gaming Pc, I have no clue how to change my ram speeds.
My ram is G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory
And my motherboard is the Gigabyte GA-Z170XP-SLI
You can change your RAM speeds in your BIOS settings.
Enter your BIOS when your PC boots up, and there should be an easy to find RAM option. Just make sure your components support the speed that you're setting it to, otherwise you'll get BSODs.
