Need help on choosing a TV card
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    HD
G
Guest
Guest
Hey
I want to connect my Sky set top box to my PC and hopefully record in 1920x1080 if its possible. My PC has 6gb DDR3 RAM, Intel i7 920 at 4Ghz, 2 x 1TB HD's and a GTX260 graphics card. Can anyone recomend a good TV card thats not to pricey.
Thanx
Compro E900F
ASUS My Cinema-PE9400
Hauppauge WinTV-HVR-2250
One thing I noticed about the Compro E900F was that it had a pass though for you case's power button to let your remote turn you computer on and off. Don't recall seeing that on the others.
Be sure to check out AntennaWeb.org to see what free TV you can get.
As for antenna, what are you able to use? Can you have a large roof mount, med one mounted in attic, or does it have to be small and in the same room?
