Hey guys, I plan to build my first computer. I have been researching for hours on the parts I want to get. I shall continue on with my current specs, and then after I list those I will list the parts I want to use for my next build.
Current computer specs:
CPU: Intel core i3 530
GPU: EVGA Gefore GTX 560 ti
Motherboard: Gigabyte H55M-S2H
Memory: 6 GB of DDR3
PSU: Rocketfish 500W
HDD: 1 TB
Also have a standard optical drive and all the other things that come with a prebuilt computer (it is a CyberpowerPC)
What I plan to include in my new build:
CPU: Intel Core i5 4670
GPU: Sapphire Radeon HD 7870 (I got it for $135 on Newegg on Black Friday
Motherboard:
GIGABYTE GA-H87-D3H LGA 1150
HDD: Western Digital WD Blue 1 TB 7200 RPM
PSU: I haven't really decided on the PSU yet, I was thinking of getting a Corsair 600 - 700W power supply, suggestions would be nice!
Case: I have also been unable to decide on a case, suggestions are welcome. I may refer to the link I posted in the motherboard section below for a case for last resort if necessary.
OS: Windows 8.1
There you go! Now I will give some reasoning behind the parts I chose.
I chose the CPU I chose after reading that the FX 8350 uses more than twice the amount of power consumption that the 4670 uses and provides less significantly overall performance in single-threaded applications. The link to where I found this can be located at
http://cpuboss.com/cpus/Intel-Core-i5-4670-vs-AMD-FX-8350
I am the type of guy who is very....what is the word....efficient? I know that over time (and I plan to have this processor for awhile) the costs of the extra power consumption of the FX 8350 will add up very much.
I do not want to overclock, so I assume the stock fan for the CPU is fine.
I chose this motherboard after visiting this site: http://techreport.com/review/25743/tr-christmas-2013-system-guide/2
and seeing the good reviews of the motherboard on newegg.
As I mentioned above, I got a really great deal on the graphics card and I plan to use it in my next build.
I am hoping to grab these parts when Newegg rolls out the After-Christmas sales!
I was also hoping that I could use the same RAM and optical drive from my current computer in order to save some $.
For anyone of those wondering, here is the order of applications from most-time-consuming to least-time-consuming in my everyday life.
1. Minecraft
2. Youtube
3. League of Legends
4. Battlefield 4 along with many other Steam games I have
Thank you for reading this wall of text! Hopefully you guys can help me out here in deciding what I should get.
HDD: 1 TB
Motherboard:
OS: Windows 8.1
1. Minecraft
2. Youtube
