Need help on finalizing my first UNDER 600 dollar pc build
It should do the trick. Your GPU might be bottlenecked, but only if you're doing the intensest intense stuff. The bottleneck might show itself by a loss of at most 2 or 3 fps.
For a $600 budget, it will do just fine.
My friend has an OS but its on a CD
