Need help on first build
rudo2mas
204
These are the current parts I've thought of going with excluding the graphics card because I am saving up for a GTX 780.
So excluding the graphics card my budget is around $500.
Intel Core i5-3570K 3.4 GHz Quad-Core
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
ASRock Z77 Pro4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
These are parts I have in mind. I need help on a power supply and your thoughts on what I've picked out.
Thanks!
pcpartpicker only has reputable vendors on their site, i also did manage this as well
PCPartPicker part list: http://pcpartpicker.com/p/3239r
Price breakdown by merchant: http://pcpartpicker.com/p/3239r/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3239r/benchmarks/
CPU: Intel Core i5-4670 3.4GHz Quad-Core Processor ($209.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($32.99 @ Mwave)
Motherboard: MSI Z87-G55 ATX LGA1150 Motherboard ($127.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($74.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 780 3GB Video Card ($499.99 @...
I do have an OS and I have a cheap optical drive. Sorry for not mentioning that :)
I will not be overclocking and idk. Is there a big difference between the 3570k and 4670k? Does the 4670k cost a little more?
I'll go with the ram and HDD and PSU you picked out. I should have also mentioned I have discount on the Intel CPU I am planning on getting which is why I picked that out. So I would need a motherboard that supports it.
PCPartPicker part list: http://pcpartpicker.com/p/3224b
Price breakdown by merchant: http://pcpartpicker.com/p/3224b/by_merchant/
Benchmarks: http://pcpartpicker.com/p/3224b/benchmarks/
Motherboard: Gigabyte GA-H87-D3H ATX LGA1150 Motherboard ($99.24 @ Amazon)
Storage: Western Digital RE3 750GB 3.5" 7200RPM Internal Hard Drive ($50.94 @ Amazon)
Case: Rosewill CHALLENGER ATX Mid Tower Case ($45.19 @ Amazon)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($69.99 @ NCIX US)
Total: $550.34
(Generated by PCPartPicker 2014-03-01 01:43 EST-0500)
went over but its everything you need for 550
you should also be looking for ddr3 memory with a cas latency (cl) of 8 and a speed of 1600 and the set must be dual channel ie (2x2gbs, 2x4gbs) and the voltage cannot exceed 1.5 voltage as the memory controller is only rated for 1.575v
the 212 htper evo is compatible with almost anything and yes it works with the 1155 socket i chose this motherboard because it is really well recieved and supports sli just in case you want to add another 780 later down the road and i changed the power supply because the xfx core edition is actually one of the better ones you can get and it is cheaper
PCPartPicker part list: http://pcpartpicker.com/p/32309
Price breakdown by merchant: http://pcpartpicker.com/p/32309/by_merchant/
Benchmarks: http://pcpartpicker.com/p/32309/benchmarks/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($209.99 @ SuperBiiz)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($119.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 780 3GB Video Card ($499.99 @ NCIX US)
Case: Apevia X-Plorer2 Black/Blue ATX Mid Tower Case ($62.99 @ Mwave)
Total: $1130.92
(Generated by PCPartPicker 2014-03-01 02:27 EST-0500)
Looks good 😀. One thing though, is Ncix a reliable site to buy from. I've actually never heard of them and is there a reason why they're components cost less then, lets say, newegg? I mean the same PSU is almost $100 more on newegg, lol.
Total: $1138.92
(Generated by PCPartPicker 2014-03-01 02:37 EST-0500)
it has the new i5 and 1150 socket motherboard for 8 dollars more the only thing is you cant over clock and the 4670 is slightly better than the 3570
