Need help on first PC Build
RogueMarauder
46
I am no Computer Expert. I should also say that this isn't something I did much Research on. (Hopefully you guys will help because I don't really know how else to check, efficiently) Anyway guys please just tell me what you think, any compatibility problems, or problems with how it could run. Basically if there's something wrong with the build just tell me and please give suggestions on how to fix it.
(Sorry no Picture, have to type)
RAM- Corsair Vengeance Pro Series 16GB DDR3 DRAM 2400MHz C11 Memory Kit- $159
CPU- Intel i7-4709K Processor (8M Cache, up to 4.40 GHz) - $300
Motherboard- ASUS ATX DDR3 1600 LGA 1150 Mother Board Maximus VII Formula-$307
Hard Drive- Western Digital 2 TB SATA III 7200 RPM 64 MB Cache Bulk/OEM Desktop Hard drive, black- $105
Video Card- EVGA GeForce GTX 750Ti Superclock w/G-sync Support 2 GB GDDR5 128 bit, Dual Link DVI-I, HDMI, DP 1.2 Graphics Card- $135
Monitor- ASUS VS228H-P 22 inch Full-HD 5ms LED-Lit LCD Monitor- $137
PC Case- NZXT Guardian 921 RB ATX Mid Tower Case, Black 921 RB-001-BL $65
Power Supply- Corsair CX Series 750 Watt ATX/EPS Modular 80 PLUS Bronze ATX 12V/EPS12V 744 Power Supply CX750M- $80
Sound Card- ASUS XONAR DG Headphone AMP & PCI 5.1 Audio Card- $28
Like I said please tell me what needs to be fixed, because I am not a knowledgeable guy when it comes to Computers, and tell me if I left Something out
jerryvaberry
361
What is this for? Because initial observation suggests that you ditch the unnecessary cpu and mobo, and get an ssd and something better than a 750 ti. You can find an i5-4690k and a decent oc mobo for probably around $350. Also that psu is not very good. Something from xfx or seasonic would be ideal.
