G
Guest
Guest
I recently decided to try and build my first computer and after getting everything together I powered it up for the first time. The guide that i've been using says I should hear 1 beep. As it stands I hear none.
The monitor comes on and I get the first screen that gives me the option of hitting delete to go into the bios and then it goes to a hardware monitor screen that has some temps and voltages listed.
Should I be concerned with not hearing the beep.
Also its a biostar ta790gxb a+ MB, an amd Phenom 2 x4 940.
