Hi guys I need to know if this GPU will fit properly with this case.
http://ca.pcpartpicker.com/p/pCf8xr
On the bottom of the page it says "The NZXT Source 210 Window ATX Mid Tower Case supports video cards up to 330mm long, but video cards over 230mm may block drive bays. Since the Gigabyte GeForce GTX 660 2GB Video Card is 256mm long, some drive bays may not be usable."
If it does fit, what might I be missing out on in the future? Thanks in advance.
