techmama :
I have a Toshiba Satellite P75-A7200 how do I remove the keyboard? It doesn't look anything like my old Satellite L505D.
To remove the keyboard, remove the battery, the bottom access panel and the hard drive. Remove all the rubber screw covers and screws (20+) on the bottom panel. Lay out the screws out on a flat surface in the pattern in which they were removed for easy reassembly. Remove the optical drive (and two more screws under it) then lift the bottom off of the main chassis from the front edge. There are two plastic clips under the #2 hard drive compartment and three clips on the back edge of the battery compartment that you may have to wedge a small screwdriver into to release the base. It should come off fairly...
