Need help on my build, recommendations?
I’m assuming you already have peripherals, monitor, case, operating system, and storage drives? Otherwise, try to up the psu to 550w, especially if you want to consider an upgrade or two in the future. If you plan on OC’ing, consider an aftermarket cpu cooler (doesn’t have to be liquid). Otherwise, PUBG should do OK.
