Hi all, I'm planning my first build and I'd appreciate it greatly if you gave me advice
http://pcpartpicker.com/list/Ymw6XH
So above is the current planned build. My budget is around 1700ish euro, the cost of the above build.
CPU: I chose the i5-6500 as I have no experience in overclocking, don't know how to do watercooling and don't have the budget for it, and I read overclocking your cpu won't make such a high difference in performance. Also I read that since I'm going stock cpu the fan that comes with it is enough.
Motherboard: All sources I have read point towards this one being the best option. I know I said I don't know anything about overclocking however this doesn't mean I won't research about it and even give it a go in the future. And for a difference of 30 euro I'd rather have the best motherboard option.
Ram: I need guidance here. I chose the DDR4 2666 memory ram because the difference between the 2666mhz and 2133mhz is only around 6ish euro. However as I said I don't know what this means, I only went the assumption that the higher number means higher performance. Again I need help here.
SSD: pretty much the best SSD I could find, cheap.
HardDrive: pretty standard, I could add more storage if I need in the future.
Graphics Card: This is where it gets interesting. I chose the GTX 1080 because I can get it at a relatively cheap price ~600 euro. I went with the EVGA model after some research showing that the difference between 3rd party models is minimal and that EVGA warranty doesn't become void when overclocking and they have the step up program (I haven't researched this fully yet).
Case: sleek, good cable management, I like it.
Power Supply: enough wattage, good power supply
Now I need some help with regards to the graphics card and the monitor. I was originally going to get a gtx 1070 and a 1080p 144z monitor. However since I can get a good price on the gtx 1080 I chose to get that and a 1440p 144hz monitor. I have no experience with this, that's why I need your help. I won't be gaming competitively, I will be mostly playing with friends online just to have fun. I'll surely be playing a bit of everything, CS GO, battlefield, GTA V, the witcher, dark souls 3, and similar RPGs. I could have gone with a gtx 1070 and 1440p 60hz monitor or 1080p 144hz monitor. I chose the 1440p 144hz version with the gtx 1080 since as I will be playing some RPGs I'd like to have a nicer picture, rather than just for playing competitively. I also don't want to upgrade everything every summer, I'd like to just build this pc to be covered for the next 3 years, hence why I chose the 1440p 144hz monitor. If further on the gpu won't be able to handle new games at 1440p, I'll downscale to 1080p and play at 144hz. However this is all just my opinion, and I greatly value yours as, again, I don't have much experience. Thanks
