Dear experts,
Really need your generous help on my PC as it cannot be start after several
times of blue screen appeared. The mobo doest boot at all which only the fans
are working and it just stuck with a blank black screen.
I've also tried to update the bios by changing the "Clear RTC" jumper
from 1-2 to 2-3 and plug in a thumb drive with latest bios update. It doest
work at all and it gets worst, The fans and everything totally can't start.
Kindly please advice what on should I do. Thank you
PC specs:
Win 7 64bit
Mobo: P5Q Pro
CPU: intel Quod Core 6600 2.66
Ram: Ocz Reaper 2gx4
GPU: HD4770 x2 (crossfire)
PSU: CM silent pro 700w
HDD: Samsung 1TB
Sound card: Creative Fatal1ty X-fi
PC specs:
Win 7 64bit
Mobo: P5Q Pro
HDD: Samsung 1TB
