need help on pc build!!!
fivefour.xone
21
so right now im thinking of doing:
amd fx 8350
i wanna buy a compatible motherboard that has 2 pci-e x16 so i can combine (if possible) my 1050ti with a going to buy 1070ti, both Gigabyte Nvidia.
the motherboard i was thinking was Asus M5A78L-M/USB3 but it only has one pci-e x16
cant seem to find a case that compatible as well as has an optical drive
i already have two ddr3 Kingston hyper x 8GB ram 1600mhz
ssd 512GB
8tb surveillance hdd
an optical drive
now im restating i need a motherboard that works well with fx 8350 and a case that fits that motherboard as well as 4 to 8 expansion slots and 4 to 5 drive bays (3 to 4 3.5 inches and one 2.5inch and one optical drive bay
please help!!
cheerz
You could use the 1070 ti to for your gaming monitor and the 1050 ti for other monitors however it would be a huge waste of that GPU. The 1070 ti is more then enough for a few monitors and gaming. What I would actually recommend is getting that 1070 ti, selling the 1050 ti and saving up for a newer platform such as Ryzen 2 or Intel Coffeelake as they will pair much better over that 8350. You would also need a new motherboard and DDR4 ram.
WildCard999
