I need a Comparison of these two cards:
I bought the ZOTAC® GeForce® GT 440 512MB DDR5 for my old PC however the HD crashed now I'm looking at getting a AX51 from Alienware and it comes with a Nvidia® GeForce® GT 640 1GB DDR5.
Of these two which is the card that I should use? below are the post specs.
GPU ENGINE SPECS:
CUDA Cores : 96
Graphics Clock (MHz) : 810 MHz
Processor Clock (MHz) : 1620
Texture Fill Rate (billion/sec) : 13.0
MEMORY SPECS:
Memory Clock (MHz) 3200 : (GDDR5)
Standard Memory Config : 512MB (GDDR5)
Memory Interface Width : 128-bit
Memory Bandwidth (GB/sec) : 51.2 (GDDR5)
Maximum Memory Amount : 1GB GDDR5
FEATURE SUPPORT:
NVIDIA PureVideo® Technology* : HD
NVIDIA PhysX™-ready : √
NVIDIA CUDA™ Technology : √
Microsoft DirectX : 11
OpenGL : 4.0
Bus Support : PCI-E 2.0 x16
Certified for Windows 7 : √
NVIDIA 3D Vision Ready : √
DISPLAY SUPPORT:
Maximum Digital Resolution : 2560x1600
Maximum VGA Resolution : 2048x1536
Standard Display Connectors : Dual Link DVI, HDMI, VGA (optional)
Multi Monitor : √
HDCP : √
HDMI : √
Audio Input for HDMI : Internal
THERMAL AND POWER SPECS:
Maximum GPU Tempurature (in C) : 98
Maximum Graphics Card Power (W) : 65
Minimum System Power Requirement (W) : 300
GPU ENGINE SPECS:
CUDA Cores : 384
Graphics Clock (MHz) : 950 MHz
Processor Clock (MHz) : 950
Texture Fill Rate (billion/sec) : 30.04
MEMORY SPECS:
Memory Clock (MHz) 2500 : (GDDR5)
Standard Memory Config : 1GB (GDDR5)
Memory Bandwidth (GB/sec) : 80.5(GDDR5)
Maximum Memory Amount : 1GB / 2GB GDDR5
FEATURE SUPPORT:
NVIDIA PureVideo® Technology : √
OpenGL : 4.2
Bus Support : PCI-E 3.0
3D Gaming : √
Blu Ray 3D : √
DISPLAY SUPPORT:
Maximum Digital Resolution : 3840x2160
Media Connection : VGA, DisplayPort, HDMI
HDCP : √
HDMI : √
HDMI Audio : Internal
Maximum GPU Tempurature (in C) : 102
Maximum Graphics Card Power (W) : 75
Minimum System Power Requirement (W) : 240
GPU ENGINE SPECS:
CUDA Cores : 96
MEMORY SPECS:
FEATURE SUPPORT:
OpenGL : 4.0
DISPLAY SUPPORT:
Multi Monitor : √
HDCP : √
HDMI : √
GPU ENGINE SPECS:
CUDA Cores : 384
MEMORY SPECS:
FEATURE SUPPORT:
OpenGL : 4.2
3D Gaming : √
Blu Ray 3D : √
DISPLAY SUPPORT:
HDCP : √
HDMI : √
