Need help on this build
ujjwaluberoi
27
Hi guys i am planning to use my old hp elite 8100 compaq sff and add a 1050ti(mini) with 8 gb of ram and intel i5 650 , a 500gb hdd,250watts psu would i be able to play games like fortnite,csgo,overwatch at 60fps+(high settings) and should i upgrade my psu to 300watts?? Or is it safe to use it with the 1050ti
No you do not want to run a 1050TI on a PSU that's only 250W, it won't run at all. You will need a PSU that's at minimum 450W, and make sure that you get one that is of fairly decent quality. Running it on anything less and there's a chance that it won't run at all.
That depends on what monitor resolution you're running at. A 1050TI will give you decent frames on 1080P, depending on what game you're playing you could probably achieve that. Anything above 1080P and you would definitely need a better GPU.
