Need Help on this Mini-Itx motherboard
rickpcnerd
232
I have always wanted to build a computer small as possible fitting to a size of DVD Player just for gaming replacing a console. Im not sure if a Mini-Itx with pci-e 16x is compatible to a Nvidia 8800 gt. Need to know if any pci-e card is compatible or has to be a specifig card design for mini-itx. This is the motherboard Specs.
CPU: LGA775, Supports Intel® Core 2 Duo processors, 533MHz / 800MHz / 1066MHz
Memory: Two DDR2 sockets support up to 4GB DDR2 SDRAM, PC533/667/800 DDR SDRAM
Chipset: Intel® Q965 chipset & ICH8
Video: Intel® Q965 integrated graphic sybsystem (GMA3000)
I/O: JMicron JM368 (PCI-e to PATA) supports 1 PATA channel, One RS-232 and one RS-232/422/485 COM ports, Supports 4 SATA II Ports, Supports 6 USB ports (4 ports + 2 ports via pin header), PS/2 Keyboard & Mouse ports, 1 PCI-e (x16) slot, 8x2 pin header for adaptor card: ID394 (2 or 4 serial ports)/ ID395 (TPM 1.2 function), PS/2 KB/Mouse Mini DIN, VGA CRT, COM1, 2x RJ-45, 4x USB, Triple jack for audio, 4x SATA, USB5/6, COM2, Digital I/O, 7.1 channel audio, IDE (40-pin), CPU fan, system fan, ATX power (24-pin + 4-pin)
LAN: Intel 82562V 10/100 BaseT Ethernet
Audio: ICH8 integrated audio with Realtek ALC888 codec
http://www.ibasetechnology.net/mi900.html
I just visited a website called mini-itx.com. You might want to check them out. Don't know why you need such a small format. the 8800gt requires a decent power supply and airflow, which mini-itx cases aren't designed for.
well, im going to build my own case (dvd player style). Will use a pci-e 16x riser, wish will allow my to put my video card horizontal. Have everything design with good air flow. My idea is to replace my xbox 360 with something better with better graphics, with a machine capable playing games at 1920x1080. Just need to know gaming cards are compatible to mini-itx mobos.
