Need Help, Optiplex 3010 case too thin for GTX 1050!
enterthespark
Commendable
Oct 21, 2017
9
Hi, I went to install my Geforce GTX 1050 card today and found that it didn't fit quite right.
My PC case is:
41cm x 10cm x 36cm (DxWxH). The issue is the Width.
I lay my pc on its side, motherboard resting horizontal inside. which means the PCI port is facing up to the side panel.
Motherboard is 042P49 Dell- small form factor.
The graphics card is 12cm tall, whereas the width is 10cm.
~What are my options? Can I somehow lay the graphic card on its side?
return the card
get a low profile card
or buy a riser cable and somehow hold the card in a way that it will not rattle around inside the case, maybe with zip ties?
