Hi guys, i've never done any ram or CPU overclocking be4, i've only done overclocking for graphics cards, so i'm very new on this, i hope u guys can help me out. The only thing i know about overclocking CPU is that you can alter the FSB frequency, the multiplier, and Dram timing control, and also changing the CPU voltage. As for the ram, i'm not so sure.
Anyway, here is my setup:
Asus HD4870
Asus P5Q motherboard
Apacer 2X 2GB DDR2-800 PC2-6400
Intel Core 2 Duo E8400 CPU 3.00Ghz
Acbel iPower 650W PSU
I've already read guides from this forum and done Google searches, but they don't really work for me because either the motherboard is different than mine, or the CPU is different, or that some guides have too many terminologies and i just can't understand them at all. All i want is simple intructions, or even better, just figures or settings so that i just have to edit and apply it.
I want to OC my CPU from 3.00Ghz (stock) to 3.5Ghz which should be pretty easy coz i know the E8400 can be OCed to 4.00Ghz.
Here's the settings i've altered currently:
FSB Strap to North Bridge: 333mhz
Dram Timing Control: 5-5-5-18
FSB frequency: 400mhz
Dram frequency: 961mhz
CPU Voltage: 1.3V
CPU Multiplier: 9 (max)
I'm not sure if that setting is good or not, i booted my PC fine and didn't get any bluescreens or lockups or crashes, i haven't done any stress tests yet but i checked CPU-Z and now my CPU is at 3.6Ghz so i think i've done it?
But as for the Dram frequency, i've read in a few guides that the recommended frequency should be set to 1067mhz, and that's if you are setting your FSB frequency to 400mhz to 433mhz.
The thing is, i only get these options:
DDR2 - 801mhz
DDR2 - 961mhz
DDR2 - 1280mhz
so i'm i chose 961mhz. I'm not sure if that's safe or not, as in if it's a stable setting.
Anyway, please give me some suggestions, thanks.
Asus HD4870
CPU Voltage: 1.3V
DDR2 - 801mhz
DDR2 - 961mhz
DDR2 - 1280mhz
