L lrot123 Prominent Jan 1, 2019 100 0 580 Jan 22, 2019 #1 Hello. I need help overclocking my AMD FX-6300. I have a GA-78LMT-USB3.0 R2 so will there be a limit that I have to stay under? Thanks
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Jan 22, 2019 #2 That board only has a 4+1 power phase design , not really a good scenario for OC. Upvote 0 Downvote
L lrot123 Prominent Jan 1, 2019 100 0 580 Jan 22, 2019 #3 That board only has a 4+1 power phase design , not really a good scenario for OC. Ok, how high do you think i could overclock it. Currently it is at like 3.8 ghz and 1.3625 volts Upvote 0 Downvote
L lrot123 Prominent Jan 1, 2019 100 0 580 Jan 22, 2019 #4 I figured out how to overclock higher with AMD overdrive, what do you think the highest I will be able to go safely is? I have done 4100 mhz and it ran fine. Upvote 0 Downvote
C Crosslhs82x2 Splendid Aug 12, 2017 2,117 379 27,840 Jan 23, 2019 #5 Well you got it to it's turbo speed. Upvote 0 Downvote
