• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Need help Overclocking GTS 240 1GB
techno20
139
I want to Overclock my GPU, but i dont know to what settings
Heres what they are right now:
Core Clock (MHz): 675
Shader Clock (MHz): 1620
Memory Clock (MHz): 1100
Fan Speed (%): 39
Please could anyone help me. :)
9_breaker
865
19
all gpu's are made differently so you wont get the same overclock as another person with the same card. youre going to have to use a program like msi after burner and put the core clock up by 10mhz then check for artifacts . keep doing it till you see artifacts then when youdo put it down by 15mhz and right down your setting .then put it to default. then do the same with the memory clock . once thats done put them both at the settings you wrote.
Similar threads
