Need Help overclocking I5 4670k new to intell overclocking
JAYFRESH1271
171
New to Intel overclocking since my old system was base on the AMD 8350 so i need help to try to overclock my I5 4670K to at least 4.4 to 4.5mhz need bios setting plss thank you !!!
ASRock Z87 Extreme4 Motherboard Intel I5 4670K Sony Optiarc 24X DVDRW SATA OEM, WD Caviar Blue 1TB SATA HD 7200/32MB/SATA-6G, Corsair Vengeance LP 16GB PC12800 DDR3 1600MHz 2x4, Thermaltake Overseer RX-I Full Tower Gaming Case, GeForce 660 SC, Noctua NH D14 Aircooler CX750M power supply
I think you mean ghz, not mhz 😛
Anyway I can't give you exact bios settings because every CPU is different and your overclock depends on several factors. However this guide should give you a general idea of what you have to do, then you should be able to find your sweet spot yourself:
http://www.youtube.com/watch?v=0CHs5_TdpXE
Also you might want to check out Intel's tuning plan in case you're worried about damaging your CPU. If you have any specific problem during your overclock please let us know!
yes sorry Ghz i am going to look at the video to see i it helps thanks
It took me to get 4.3ghz n run prime95 small FFT 3:10 hours with no problem these settings trying to get to 4.4Ghz with no luck
CPU Mult 43x
CPU Cache mult 35
CPU Vcore 1.3
CPU Cache Voltage 1.2
CPU Input Voltage 1.91
rest on auto n
all c state disable
LLC level 1
