Hello world, I am new at this forum and I have a question.
I have two overclocked GPU's, "Point Of View 8600GT 512MB DDR2"
Stock Clocks:
Core: 540mhz
Memory: 400Mhz
Fan Speed: Auto
Overclocked:
Core: 612mhz
Memory: 450Mhz
Fan Speed: 100% (Manual)
And its doing just fine, It looks a good sweet spot, got a +7FPS Difference.
I have 50c Idle and It barely reaches 65c in game. However stress software like the MSI Kombustor may reach it on 80c based on these settings.
I also tried Increasing the PCIe Bus clock on the Slot 1 from 100mhz to 130mhz but put it back to 100mhz because of instabilities. Probably because it only works for the slot 1.
I want to try changing the voltages values, but not doing anything stupid before asking from the experienced.
In the bios, everything is auto, and the default CPU voltage is 1.30000v, I've been told if I increase the voltage I can overclock the cards further more. But I don't have any idea about voltage controls.. Well also I don't want to cause any damage to my GPU or Motherboard either, even if Gigabyte promises me High Durability because of N650SLi-DS4L's solid capacitors I'm still not doing anything risky.
There are voltages adjustments like, VCC12_DL, NB/HT-Link, FSB, Southbridge etc and I have no Idea what are they. So I could ask some help, I don't really want to overclock my cpu though, I only want the GPU if possible. Thanks in Advance.
My full gear:
Mobo: GA-N650SLI-DS4L
RAM: 1x 2gb Mushkin 800mhz
GPU: 2x Nvidia Point Of View 8600GT 512MB DDR2
CPU: Intel Core Quad q6600 @ 2.4GHz
PSU: Xilent 750W
HD: 500GB SATA 2
Stock Clocks:
Core: 540mhz
Memory: 400Mhz
Fan Speed: Auto
Overclocked:
Core: 612mhz
Memory: 450Mhz
My full gear:
PSU: Xilent 750W
HD: 500GB SATA 2
