First of all my current specs are:
AMD Athlon 64 x2 4800+ (OC'd to 2.75GhZ)
ASUS M2A-VM MoBo
OCZ reaper 2x2gb DDR2 800
on newegg (where I bought my ram) it lists the timings at 4-4-4-15. My memory
I installed it and everything is looking OK except my timings are at 5-5-5-18.
As far as I can tell I can not adjust my timings in the BIOS only the memory voltage witch I switched from auto to 2.1v because thats whats its rated @ on newegg My MoBo
here are the cpu-z images,
Is there any way I'm not thinking of to adjust my timings to 4-4-4-15 or better? Is 4-4-4-15 a noticeable difference from 5-5-5-18?
ASUS M2A-VM MoBo
