[SOLVED] Need help overclocking RAM
Dec 16, 2020
Hello, I have Asrock z390 phantom gaming 4 sli motherboard and want to oc my ram's xpg spectrix d60g 2x8gb but every time I pick the xmp profile 1 or profile 2 after rebooting it shows that the frequency is 1066 mhz. What am I doing wrong? Should I try set everything in the bios manualy? If so, what to change? Cpu is i5-9600kf. Please help!
update the BIOS of your motherboard to the latest version 4.30, reset the BIOS by jumper and try again setting the XMP profile 1 (F10 save and exit)
Are the Dimms installed in A2 and B2 slots?
