Need help: overclocking with ASUS p5B-deluxe
Victor79
15
I have E6600 running at 320x9, voltage set to AUTO Ai-Suite shows 1.4 . Why so hight? Seems like MB slowly incresases voltage itself to support my overclocking. Should I care about it?
Temperature now 40 degrees, speed 2879.79, full load (computing SuperPi in two windows).
Main question is that it seems I can not change 4:5 ratio with ram. I wanted to set it 1:1 and try 400 (RAM Corsair, DDR2x800). I could not find the option to change this ratio in BIOS.
Its my first overclock, how far should I go?
There is no setting to change the ratio...
if you want 1:1 then put the FSB at around 400 (401 up for that board) and voila, your FSB and RAM are at 400... 1:1.
Conversely, you could slow down your RAM at lower a lower FSB.
There are a million threads on a million sites about OCing that board, BTW.
Cheers
