Need Help PC Monitor Turns Blue
David131
http://pcpartpicker.com/list/sTt6r7 this is basically my PC
When playing dota 2 my monitor would go blue with a message saying hdmi no signal while the pc still ran. I turned down my settings and that helped for a while but now even with basic graphics this happens all the time so i thought it was specific to do dota but then i tried to run tomb raider with ultimate settings (just to see) and the same thing happened again. please help i cant enjoy my favourite games like this.
It most likely has to do with bad drivers in your GPU (graphics Card) or just a bad GPU in general. It could be the wire connecting the GPU to the monitor that is bad as well. When this error usually occurs its either your RAM, your harddrive or your GPU. Either way you should uninstall the drivers related to your GPU and reinstall them. If that doesn't work, if you have a spare GPU or spare RAM lying around, try to switch them out and see if the error persists.
i did that driver thing and it seemed to be working but at the very end of the first game it started happening again i replaced the cable and it did the same thing and i dont have any spare ram or a gpu around
