Question Need help pc wont turn on!
Jan 27, 2022
8
My pc kept turning off so I change the thermal paste and made sure all the the cobles insider where connected but it still turned off then it stoped even turning on any more then I noticed the power cable was loose and I plugged it in properly and now it still won’t turn on I’m worried that something inside fried now. What should I do?
Jan 27, 2022
8
I unplugged the power supply and now it turns on but it still is turning off but each time I turns off it last less and less time so now instead of adding thermal paste I’m going to remove it and put new paste on
