I recently built my own pc in the Phanteks 350x case and everything works great except there’s only one problem: the pre installed case fan won’t spin. I read the manual and did all the connections but it still doesn’t seem to work. Help?
I have a 550W Rosewill PSU and the motherboard is MSI B350M PRO-VD PLUS AM4 AMD B350 SATA 6GB/s USB 3.1 Micro ATx AMD motherboard. As for the fan connections, nothing was needed to be plugged into the motherboard. The fan is preinstalled and connected to the fan hub and is supposed to be powered via the data cable, which also supports the built in RBG for the case. The RBG works, but the fan doesn’t.Does the Fan just have one 3 pin (or 4 pin) connector ?
What exact model MB & PSU are you using ?
Sata cable*I have a 550W Rosewill PSU and the motherboard is MSI B350M PRO-VD PLUS AM4 AMD B350 SATA 6GB/s USB 3.1 Micro ATx AMD motherboard. As for the fan connections, nothing was needed to be plugged into the motherboard. The fan is preinstalled and connected to the fan hub and is supposed to be powered via the data cable, which also supports the built in RBG for the case. The RBG works, but the fan doesn’t.
theres not more on the hub. Also, this is a really rookie question but case fans should spin upon startup, correct?Are there multiple fan ports on the hub ?
If so have you tired moving that fan to a different port.
Also I'd try connecting it directly to the PSU via a SATA power connector and see if it spins up then, if it doesn't you will know the fan is bad.
If it does power up then you need to figure out why the fan hub isn't powering it.
thats the thing, my mb doesnt have another header. Would trying a different SATA port for the hub maybe work?See if you can connect the fan directly to a SYS-Fan or Case_Fan header on your MB.
If the fan has a 3 or 4 pin connector it can be plugged into any 3 or 4 pin header on your MB.
Look on page 13 of your Manual for info on the SYS_Fan Header.
And yes it should start spinning when the PC boots.
ah i see. I will try later today as im out and I will get back to you. Thanks!According to the MB Manual it does have 1 SYS_Fan header look on page 7 and 13 of the manual.
https://www.msi.com/Motherboard/support/B350M-PRO-VD-PLUS#down-manual
So connect the fan directly to that header and see if it spins up.
also sort of a last resort question. I have a 550w power supply, a gtx 1050ti, and a ryzen5. My CPU fan works. Worst case scenario, if this doesn't work. Will my pc still overheat even if the heatsink fan works?ah i see. I will try later today as im out and I will get back to you. Thanks!
also sort of a last resort question. I have a 550w power supply, a gtx 1050ti, and a ryzen5. My CPU fan works. Worst case scenario, if this doesn't work. Will my pc still overheat even if the heatsink fan works?According to the MB Manual it does have a SYS_Fan1 header look on page 7 and 13 of the manual.
alright so i figured out the issue i think, the fan is just faulty. last question, i am thinking of installing a fan on the rear panel. 1) does the fan on the rear panel have to be an exhaust or intake fan or does that not matter, and 2) do case fans have to connect to the PSU directly or do they just connect to the mother board and get power from the motherboard?I personally have 5 case fans running (3 intake and 2 exhaust) to keep my CPU, MB, etc. as cool as possible.
I have a Ryzen 5 260 0@ 3.95 GHz, an MSI GTX 1660 Ti and a LOT of HDDs and SSDs.
I would highly recommend you install at least one intake and one exhaust fan BUT with case fans more is better IMO.
If the fan controller or the MB fan header don't work properly you can always buy fans that use SATA power connections as a last resort and they will just run at full speed.
cool thanks! i appreciate the help. I guess my last question before taking any action is, since my motherboard only has room for 1 more sysfan, should i worry about the negative pressure that would come from only having an exhaust fan? or does that not matter since I can really only have 1 more system fanI would definitely make the rear fan an Exhaust fan to get rid of the hot air coming off of your CPU cooler/MB VRM/etc.
As for power it depends on the fan.
Some fans connect directly to the MB with a 3 or 4 pin connector and they don't need any other power source.
Also those 3 and 4 pin fans can have the speed controlled in your BIOS
Others use a SATA or older Molex connector and they just run at 100% unless you add a fan speed controller for them.
alright and in the event that the hub is busted too would just 1 exhaust fan be ok?I would install 1 front intake fan connected to that fan hub and 1 rear exhaust fan connected to the (SYS_Fan header) running slightly slower to keep positive pressure.
So the splitter will connect to the motherboard and the 2 fans at the same time? I’m fine with that, but wouldn’t that make cable management difficult, or would it not matter since the splitter would be hidden with the rest of the messy PSU stuffIf the hub is bad I would get a fan splitter cable and connect the front intake and rear exhaust fans to the SYS_Fan header just to be safe.
Thank you for all your help man.Yes the splitter would connect to the header then to each fan, as far as cable management that depends on how you can best route those fan cables.
There are plenty of options for a splitter, so you just need to choose one that will work best for your setup/case as far as cable management goes.
3 pin splitters:
https://www.amazon.com/3-pin-fan-cable-splitter/s?k=3+pin+fan+cable+splitter
4 pin splitters:
https://www.amazon.com/s?k=4+pin+fan+cable+splitter&ref=nb_sb_noss_2
went out, got the parts, hooked up, bam. it works. Thank you so much again. Aprreciate the help man! i no longer overheatYou're very welcome.
Let me know how it works out for you.
