Need help picking a Gaming PC! : Please?!
JeromeCole
47
Hello, so my friend wanted to buy a Gaming PC. I know all the top notch stuff however i have no clue what to recommend and i don't know exactly what is good, especially for the prices that he is saying.
First of all he has around £300.
I recommended to get an Intel CPU and motherboard due to the fact that i bought an AMD one and realised Intel was basically better, know i have to go through a long, costly process.
The PC doesn't have to have a GPU as he will be buying that later on however it must have a 600w PSU so that the GPU, once bought has enough power supplied.
If anyone could link any PC from amazon / ebay / any other legit sited that would be great thanks!
Its hard to recommend a build without knowing what GPU you will use, but, if you dont need a dedicated graphic card for now, you can go with:
Option 1
CPU: Intel Core i3-4360 3.7GHz Dual-Core Processor (£113.94 @ Aria PC)
Motherboard: Gigabyte GA-H81M-H Micro ATX LGA1150 Motherboard (£36.30 @ Amazon UK)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory (£51.72 @ Amazon UK)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive (£31.94 @ Amazon UK)
Case: Zalman ZM-T4 MicroATX Mini Tower Case (£14.50 @ CCL Computers)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply (£59.33 @ More Computers)
Total: £307.73
Generated by PCPartPicker 2015-04-11 20:12 BST+0100
Option 2
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£144.00 @ Novatech)
Total: £337.79
Generated by PCPartPicker 2015-04-11 19:59 BST+0100
Of course the second one is better, gives more assurence against bootkeneck and more future proof, but over your budget
+1; These two builds are solid builds for 300 quids!
