Need help picking a GPU
WD-17
42
So i'm planing on a little upgrade & i chose to upgrade my graphics card currently i have a gigabyte gtx750ti and i want to spend less then 300$ and i need the graphics card to work in balance and without bottlenecks with my intel core i5 4460
In that price range a 1060 6GB would be the best. Although if you're just doing 1080p and depending on what games you want to play, even a 1050 Ti 4GB would work.
is it even worth to consider buying a AMD graphics card?
If you'd like to get a nice "gaming" monitor. There are 2 options. AMD's "Freesync" monitors or Nvidia's "G-Sync" monitors. Freesync's are cheaper and require an AMD card. Same applies to G-Sync(Nvidia only) and are a big jump in price.
thanks for the help i think ill go with the 580 its more friendly to my wallet because i thinking to get a good and cheap "gaming" monitor
