Need help picking a MOBO
BattleTiger
27
Well i've been doing some research and came across this:
ASUS ATX DDR3 2600 LGA 1150 Motherboards Z97-PRO(Wi-Fi ac)/USB 3.1
and it seems like a pretty good mobo, but i've seen some bad reviews and the price is a lil much at 300$
Here is my build ATM : http://pcpartpicker.com/p/X8Lhzy
Yes this is for gaming.
well, for all the motherboard, it may have good review, also some bad reviews,
so, you may want to check with more review as well
but for your build, with i5-4670k
I think msi z97 gaming 5 is good as well, this is a gaming motherboard,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130770&cm_re=z97_gaming_5-_-13-130-770-_-Product
and if you are looking for some z97 motherboard with usb 3.1 support
try msi z97a gaming 7
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130843&cm_re=msi_z97a_gaming_7-_-13-130-843-_-Product
