Need help picking a motherboard.
Wbluke
7
This is the first Gaming PC I will have ever built. Please correct any mistakes I have made.
I have an $850 budget not including Monitor, Keyboard, Mouse, etc. On these items I have spent $700 so far. I am looking for a Motherboard and case that fits within the rest of my budget. Thanks for anyone who helps.
Intel Core i5-4690K(CPU)
Sapphire Radeon R9 290 4GB Tri-X OC(GPU)
G. Skills Ripsaw X series 8GB(RAM)
Western Digital Blue(1TB Hardrive)
EVGA SuperNOVA NEX 750W 80+ Bronze(Power Unit)
mb:
http://pcpartpicker.com/part/asrock-motherboard-z97anniversary
CPU cooler:
http://pcpartpicker.com/part/cooler-master-cpu-cooler-rrt418pkr1
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811853004&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16811853003&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
to allow for longer video card.
would HIGHLY suggest getting the cpu cooler since you're getting an unlocked cpu, and a z97 board TO more successfully overclock...
down the road you can always get a new case
mb:
CPU cooler:
Case:
or
