Need help picking between 2 PSU/MOBO/Video Cards ($1000 build)
needhelp1989
32
CASE +FAN $59.99 + $21.99+(3.99)
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
COOLER MASTER Megaflow 200 R4-LUS-07AR-GP 200mm Red LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103072
CPU $224.99 +(0.00)
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Hard Drive $59.99
Western Digital Caviar Black WD5002AALX 500GB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
Driver$19.99+6.98
ASUS Black 2MB Cache SATA 24X DVD Burner - Bulk – OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Total = 1058.00
PSU 79.99
Antec TruePower New TP-650 650W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC "compatible with Core i7/Core i5" Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021&Tpk=Antec%20TruePower%20New%20TP-650%20650W
Or
PSU $89.99
Antec TruePower New TP-750 750W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC "compatible with Core i7/Core i5" Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025&cm_re=750w-_-17-371-025-_-Product
Video Card
$249.99+ (7.56)
EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604&cm_re=GTX_560_Ti-_-14-130-604-_-Product
Or
Video Card $249.99
MSI N560GTX-TI Twin Frozr II/OC GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127565
MOBO $159.99
ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229&cm_re=13-157-_-13-157-229-_-Product
Or
MOBO $149.99
ASUS P8P67-M PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131707
Video Card
post which ones you thing are the best, and why.
Thank you in advance
Similar threads
