Case: lian li air
https://www.overclockers.co.uk/lian-li-pc-o11-air-rgb-midi-tower-black-window-ca-76v-ll.html
Gamer nexus review (filter problem)
https://www.youtube.com/watch?v=ctKKTeaNpb8&t=548s
First off my fan setup will be as follows.
3 120mm rgb fans at the front (intake)
2 120mm fans at the bottom ( intake under GPU)
dual 120mm fans at top of case (exhaust h105 aio)
Do you guys think my fan setup is adequate?
As for the front dust filter. I'm thinking about buying 3 of these silver stone filters to replace the apparently bad stock FRONT filter. What do you guys think?
https://www.amazon.co.uk/SilverStone-SST-FF123B-120mm-Filter-Magnet/dp/B00ARB5E8U
