Need help picking out router for multiple users
manne11
43
So im on a tight budget and i am wondering what router is good for streaming, gaming, and browsing on a 10Mbps connection with 3 people on it. right now im looking at this router any suggestion on a router is welcome. thank you in advance.
[strike]That will 'work' but maybe not too well. What is your budget?[/strike]
Actually scratch that. If you don't have a big house, that will probably work fine for what you need. If you do any gaming, try to use an ethernet cable and connect directly to the router.
This one is only $5 more, and might be worth the extra http://www.amazon.com/dp/B003Y5RYNY/ref=psdc_300189_t3_B001FWYGJS
This one http://www.amazon.com/dp/B0098QV038/ref=psdc_300189_t2_B001FWYGJS would be the next step up at $45, and if you have newer devices, you can use the 5Ghz wireless too.
