Hey all,
I am in need of help picking out the specific GTX 760 card I want to purchase. I am torn between a few different brands. First off, I will be gaming on my Samsung 1080p 50 inch plasma TV in the living room. Here's the specs on what I have now:
Processor - Core i5-3570k (running at stock speeds at the moment)
Cooler - Cooler Master Hyper 212 Evo
Motherboard - ASUS P8Z77-M Pro Micro ATX
Ram - 2x4GB Crucial Ballistic
Power Supply - Corsair CX600m
Case - Silverstone SST-PS07W
Here's the first issue: the case. The Silverstone I bought mounts the motherboard upside down as you can see here towards the bottom of the page. The 2 120mm fans along with the CPU cooler and the rear 120mm exhaust fan I installed funnel cool air from the front of the case through the back. In this situation I am thinking that the blower style fan of the reference card would keep the overall case temps and subsequent CPU temps the lowest. Right now my processor running Borderlands for 4+ hours using the onboard HD4000 Intel Graphics maxes out about at 50 C. I would like to keep it low to overclock later but I would also like to spend the extra $10 to get a factory overclocked card with a better cooler for the GPU.
Since the GPU being installed will be installed "upside-down" as compared to other "normal" cases, I am assuming the aftermarket coolers with multiple fans would be exhausting the heat upward away from the CPU and not affect my CPU. Do you all agree with that assumption?
Here's the cards I am thinking about buying and why:
EVGA GeForce GTX 760 SC w/ ACX Cooler
EVGA 3 year Warranty and high end bearings for the cooling fans per the website.
GIGABYTE GeForce GTX 760 GV-N760OC-2GD REV2.0
Windforce Cooling along with the highest stock overclock. Also the MSI afterburner software.
MSI N760 TF 2GD5/OC
Twin Frozer Cooling and tied with the Gigabyte for highest stock O/C
Asus GTX760-DC2OC-2GD5
Brand Matching to the motherboard, the ASUS Direct CU II cooler, but the lowest stock overclock. Also is the shortest card but my case should be able to handle cards up to 13.5 inches.
Any help that can be offered to help me choose the best card and style of cooling solution would be much appreciated. Thanks in advance!
MSI N760 TF 2GD5/OC
