• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Need Help Picking the Right Power Supply
spyguy
232
I'm upgrading my psu but I'm confused about the connectors. I have an I7 7700k and gtx 1080 if that matters. My mobo is z270-a. I don't know how many pins the connector for the mobo requires. I read there are different kinds. Ill upload these pictures and the link to the psu. Hopefully someone can tell by looking if everything I need will be included because my current unit is not modular. https://www.amazon.com/EVGA-SuperNOVA-Modular-Warranty-220-G3-0750-X1/dp/B005BE058W/ref=pd_lpo_vtph_147_tr_t_2/134-0670893-8414020?_encoding=UTF8&refRID=MPSAB646VAHKR2XTZV6T&th=1
http://i36.photobucket.com/albums/e19/OddOne12/20180209_073744_zpsideshrfa.jpg
http://i36.photobucket.com/albums/e19/OddOne12/20171209_045337_zps0adacltk.jpg
http://i36.photobucket.com/albums/e19/OddOne12/20180209_073912_zpsqamskrbn.jpg
http://i36.photobucket.com/albums/e19/OddOne12/20180209_073857_zpsbaz07yz2.jpg
http://i36.photobucket.com/albums/e19/OddOne12/20180209_073815_zpsycvrvnwv.jpg
http://i36.photobucket.com/albums/e19/OddOne12/20180209_073808_zps9gyd94or.jpg
The G2 is an awesome unit. It will have all the standard connectors required, and some additional PCIe connectors for extra power for a high end GPU.
You will get a bunch of cables with the PSU, makes sure to use those, as opposed to the ones already in the system. Just swap them out.
spyguy
232
The unit I'm looking at is the G3, but my current psu is not modular so I wont be able to use any of the same cables. I have an ssd and hdd and I'm not sure if it comes with enough cables for both.
Typo, I meant G3.
EVGA SuperNOVA 750: EVGA SuperNOVA 750 G3EVGA SuperNOVA 750 G3: www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=500
It has plenty of cables for both. Don't worry. You'll be fine. What are you specs of your hardware. 750w is a bit overkill. Any decent 500-600w PSU you will do for a fairly decent high end system with a mid-high GPU.
The same model G3 650w will save a couple of quid. You shouldn't be using more than that, unless you have an SLI set up with GPU's/CPU overclocked.
spyguy
232
Well as far as going for the 750 its 18 dollars more and that will leave headroom for future upgrades and comes with a 10 year warranty.
spyguy
232
Also the first picture shown on this thread is a small cable connected to HD Audio on the mobo. I don't know the name of this cable and don't know if its included.
That cable should be comming front the front of the case not the power supply for the front panel audio.
spyguy
232
So that hd audio goes from mobo to where? Also my liquid cooling system only plugs into the mobo correct? And where does the JUSB3 cable go to from the mobo? Sorry I know that's alot
this info will be in your mobo manual. You will have to do a bit of reading, and match up the connections with the new PSU.
or panel audio to the mobo you have.
If you wanna spend the extra bucks that's up to you. Having the extra juice won't do any harm, but a 650 model will do fine, and give you the headroom you're thinking of.
Similar threads
