[SOLVED] Need Help! Please and Thank You
Jan 17, 2019
6
I have
I7 9700K
RTX 2080 FE
16gb DDR4 2400 ADATA Ram
Asus PRIME Z390-A Mobo
120gb ADATA SSD and 1TB IDK HDD
Corsair rm750x power supply gold +80 750watt
Play mostly BR games and get
120FPS avg in H1Z1
75FPS avg in Ring of Elysium
100-120FPS in PUBG
All usually on Medium settings
only posting this bc a buddy has
i7 7700k
gtx 1080
asus strix z270h
and he matches my games on same setting was wondering if they are really similar builds or if there is something i need to do to check and do to increase my performance
3DMARK: https://www.3dmark.com/3dm/32484546
https://www.3dmark.com/3dm/32516475?
Another Benchmark: https://www.userbenchmark.com/UserRun/13914520
^^ Says my CPU & GPU preforming way below standard any ideas?
All help is much appreciated thanks in advanced
so reinstalled windows and now im getting a PCI device not showing and cant get drivers which i found to be my mobo went to asus site for drivers and now im getting an error saying Asus setup does not support OS WNT_10.0H_64
I have ran windows update got some anti virus update nothing else, these are the bits of info i get when looking at hardware ids in device manager
PCI\VEN_8086&DEV_A324&SUBSYS_86941043&REV_10
PCI\VEN_8086&DEV_A323&SUBSYS_86941043&REV_10
after several hours of looking through things i found an older update with an "EZ" installer this has fixed my issues with the pci
