Need help please
ashleygratton
166
I have at the moment a Gigabyte R9 270x graphics card and a AMD FX 4300 quad core processor.I was planning on playing BF4 with it but I cant play multiplayer as it lags really bad.It is alright on Single player. I was thinking that it was my graphics card but it should of been fine so if I upgrade my processor to say a AMD FX 6300 will I see an increase in the fraps. I understand that I cant run it on ultra but can even run on low without it lagging severely. Any advice please.
Will I see an improvement in frames with the FX 8320. Is a Gigabyte R9 270x alright for it. On amazon the 6300 costs£73 and the FX 8320 costs £99
My net speed is fine as i acutually have bf4 on ps4 and it run superb its the fact that I got BF4 free with my graphics card so wanted to try to run it my ping is 12 if it helps
Yes, especially from that FX 4300. and that r9 270X is fine unless you want ULTRA 60fps 1080P.
how many fraps do you think i could get on say high maybe or medium and my monitor is not 1080 it resolution is 1600-900
would u recommend the FX 8320 over the 6300 or is there not a real difference how many frames difference is there if u dont mind.Sorry for all the questions im not exactly a genius when it comes to pc
