Question Need help please
Feb 12, 2019
6
Hello , i have a problem with windows 10 where sometimes out of nowhere my router is working my internet is working on all other devices but pc then i have to disable and enable my network adapter for it to work again , or click troubleshoot , it sometimes says something like " DNS server not found and have to reset adapter " , or something like " IP not found , need to reset " and it works after the reset , the thing is it's so annoying ithappens every hour or so , please tell me if anyone knows a solution for this other than uninstalling windows 10 .. coz i know that's an option since i noticed it happens only on windows but i don't really want to use any older version , ty
britechguy
Notable
Jul 2, 2019
1,271
191
990
40
Well, if you have an Intel WiFi/Bluetooth card, definitely download and install the
Intel® Driver & Support Assistant
They've been churning out driver update after driver update, along with updates to their ProSet Wireless software, over approximately the last 2 years. I had this sort of issue, and keeping the driver current using this utility has solved the issue.
Feb 12, 2019
6
No ,i don't have intel driver , i have something called Realtek , and i installed latest driver update for it , thanks for the help tho :)
