Need help -Problem with overclocking
Jack115551
Hello,
MY PC SPECS:
2x 1050 TI 4gb
2x R9 290X 4gb
1x GTX 1060 86gb
AMD A4-6300
PSU: Corsair 1000W Gold
4GB Kingston RAM
GA-F2A88X-D3HP (rev. 1.0) motherboard.
I'm trying to overclock my computer but for some reason it will not let me. It's core clock, memory clock and basically anything the cards are running at do not show. They do work as I have ran tests but when I load MSI Afterburner I can't move the slider that changes the settings, it will not even let me change the fan speed.
My computer and the program does detect the graphics card but does nothing else. I have all the latest drivers installed, and tried previous drivers. It does allow me to change settings for the NVIDIA cards with those drivers but nothing for the AMD cards...
Please help I would really appreciate it.
You can't run AMD and Nvidia cards together in a system. You also cannot run the onboard gpu on the A series chip with your cards because they are not the same series... Sorry to be the bearer of bad news, but it is not possible...
Adam
I have 5 graphic cards. The NVIDIA ones are installed correctly, as mentioned in my post I'm aware that the AMD cards are not installed correctly. I'm searching for a fix because I have tried to troubleshoot this......
Adam
