Need help quick please ! ntfrs errors
Michael
1,319
Archived from groups: microsoft.public.win2000.file_system (More info?)
Running Windows 2000 Server - I get the following entries in the event log
approx every 20 min:
Event Type: Warning
Event Source: NtFrs
Event Category: None
Event ID: 13512
Date: 8/2/2004
Time: 6:44:44 AM
User: N/A
Computer: DOMAIN
Description:
The description for Event ID ( 13512 ) in Source ( NtFrs ) cannot be found.
The local computer may not have the necessary registry information or
message DLL files to display messages
from a remote computer. You may be able to use the /AUXSOURCE= flag to
retrieve this description;
see Help and Support for details. The following information is part of the
event: DOMAIN , c:\winnt\ntfrs\jet.
Event Type: Error
Event Source: NtFrs
Event ID: 13568
Date: 8/2/2004
Time: 6:45:49 AM
User: N/A
Computer: DOMAIN
Description:
The description for Event ID ( 13568 ) in Source ( NtFrs ) cannot be found.
The following information is part of the event:
DOMAIN SYSTEM VOLUME (SYSVOL SHARE), c:\winnt\sysvol\domain, \\.\C:, 5.
Event Type: Information
Event Source: NtFrs
Event ID: 13501
Date: 8/2/2004
Time: 6:51:04 AM
User: N/A
Computer: DOMAIN
Description:
The description for Event ID ( 13501 ) in Source ( NtFrs ) cannot be found.
You may be able to use the /AUXSOURCE= flag to retrieve this description;
event:
The event log file is corrupt..
This seemed to start after there was a problem with a bad (shared) printer
driver on the server and it kept rebooting anytime someone tried to print
to it. I deleted the driver and they now print directly to the networked
printer which solved the problem, which didn't occur until I upgraded
BlackICE firewall on the server to the latest version. I think some file
or database corruption somewhere might be the cause??. Also, since this
started happening the workstations will sometimes get booted off the server
and the server has to be restarted. Might chkdsk fix it (maybe the USN
journal needs fixed?)? Can you suggest anything else? I'll be there
tomorrow early AM.
I'm not sure what happened to your event text, but I can at least decipher
the event IDs for you below. For info about tshooting FRS, see
http://www.microsoft.com/windowsserver2003/technologies/fileandprint/file/dfs/tshootfrs.mspx
13512 (This is informational and doesn't indicate a replication problem)
The File Replication Service has detected an enabled disk write cache on the
drive containing the directory %2 on the computer %1. The File Replication
Service might not recover when power to the drive is interrupted and
critical updates are lost.
13568 (This is a bad one--a journal wrap causes replication to cease. You'll
need to perform a D2 to recover. Journal wraps can be caused by running
Chkdsk--perhaps this is what happened?).
The File Replication Service has detected that the replica set "%1" is in
JRNL_WRAP_ERROR.
Replica set name is: "%1"
Replica root path is: "%2"
Replica root volume is: "%3"
A Replica set hits JRNL_WRAP_ERROR when the record that it is trying to read
from the NTFS USN journal is not found. This can occur because of one of the
following reasons.
[1] Volume "%3" has been formatted.
[2] The NTFS USN journal on volume "%3" has been deleted.
[3] The NTFS USN journal on volume "%3" has been truncated. Chkdsk can
truncate the journal if it finds corrupt entries at the end of the journal.
[4] File Replication Service was not running on this computer for a long
time.
[5] File Replication Service could not keep up with the rate of Disk IO
activity on "%3".
Setting the "Enable Journal Wrap Automatic Restore" registry parameter to 1
will cause the following recovery steps to be taken to automatically recover
from this error state.
[1] At the first poll, which will occur in %4 minutes, this computer will be
deleted from the replica set. If you do not want to wait %4 minutes, then
run "net stop ntfrs" followed by "net start ntfrs" to restart the File
Replication Service.
[2] At the poll following the deletion this computer will be re-added to the
replica set. The re-addition will trigger a full tree sync for the replica
set.
WARNING: During the recovery process data in the replica tree may be
unavailable.
You should reset the registry parameter described above to 0 to prevent
automatic recovery from making the data unexpectedly unavailable if this
error condition occurs again.
To change this registry parameter, run regedit.
Click Start, Run and type regedit.
Expand HKEY_LOCAL_MACHINE.
Click down the key path:
"System\CurrentControlSet\Services\NtFrs\Parameters"
Double click on the value name "Enable Journal Wrap Automatic Restore" and
update the value.
If the value name is not present you may add it with the New->DWORD Value
function under the Edit Menu item. Type the value name exactly as shown
above.
13501
File Replication Service is starting
This posting is provided "AS IS" with no warranties, and confers no rights.
"Michael" <michael@thecomputer.com> wrote in message
news:T7aUc.45209$US4.4119@trndny01...
> Event Type: Warning
> Event Source: NtFrs
> Event ID: 13512
> Date: 8/2/2004
> Time: 6:44:44 AM
> User: N/A
> Computer: DOMAIN
> Description:
found.
> Event Type: Error
> Event Source: NtFrs
> Event ID: 13568
> Date: 8/2/2004
> Time: 6:45:49 AM
> User: N/A
> Computer: DOMAIN
> Description:
found.
> Event Source: NtFrs
> Event ID: 13501
> Date: 8/2/2004
> Time: 6:51:04 AM
> User: N/A
> Computer: DOMAIN
> Description:
found.
> event:
server
> tomorrow early AM.
Thanks for the quick response, but the event text is posted and the event
ID's don't have anything to do with what you're referring to. Journal Wraps
are not mentioned. Also, SP4 and all later updates are installed BTW, and
this is the only domain controller or server. The server is standard Win2K.
I'm posting the log entries again - these are from the file replication
service event log:
Event Type: Warning
Event Source: NtFrs
Event ID: 13512
Date: 8/2/2004
Time: 6:44:44 AM
User: N/A
Computer: DOMAIN
Description:
Event Type: Error
Event Source: NtFrs
Event ID: 13568
Date: 8/2/2004
Time: 6:45:49 AM
User: N/A
Computer: DOMAIN
Description:
Event Source: NtFrs
Event ID: 13501
Date: 8/2/2004
Time: 6:51:04 AM
User: N/A
Computer: DOMAIN
Description:
event:
"Jill Zoeller [MSFT]" <jillz@online.microsoft.com> wrote in
news:ueMho59gEHA.592@TK2MSFTNGP11.phx.gbl:
> decipher the event IDs for you below. For info about tshooting FRS,
> see
> problem) The File Replication Service has detected an enabled disk
> write cache on the drive containing the directory %2 on the computer
> %1. The File Replication Service might not recover when power to the
> drive is interrupted and critical updates are lost.
> You'll need to perform a D2 to recover. Journal wraps can be caused by
> running Chkdsk--perhaps this is what happened?).
> in JRNL_WRAP_ERROR.
> to read from the NTFS USN journal is not found. This can occur because
> of one of the following reasons.
> journal.
> long time.
> IO activity on "%3".
> to 1 will cause the following recovery steps to be taken to
> automatically recover from this error state.
> will be deleted from the replica set. If you do not want to wait %4
> minutes, then run "net stop ntfrs" followed by "net start ntfrs" to
> restart the File Replication Service.
> to the replica set. The re-addition will trigger a full tree sync for
> the replica set.
> unavailable.
> prevent automatic recovery from making the data unexpectedly
> unavailable if this error condition occurs again.
> and update the value.
> Value function under the Edit Menu item. Type the value name exactly
> as shown above.
> 13501
Hi Michael,
Something has corrupted the FRS event log on server DOMAIN. As a result, the
text that normally appears in the FRS events you listed is missing and has
been replaced with a standard message: "The description for Event ID (
13512 ) in Source ( NtFrs ) cannot be found. The local computer may not have
the necessary registry information or message DLL files to display messages
from a remote computer. "
There is likely a KB somewhere on repairing a corrupted event log; I can try
to locate one in the morning unless you beat me to it.
In my previous message I pasted the actual FRS event log messages that
correspond to the IDs 13512, 13568, and 13501. 13568 is indeed a journal
wrap and should be addressed if you have multiple DCs; however, it looks
like you have only 1 DC so FRS isn't replicating SYSVOL (unless you are
using FRS with DFS).
news:AybUc.3567$si.667@trndny06...
Wraps
Win2K.
> service event log:
> Event Type: Warning
> Event Source: NtFrs
> Event ID: 13512
> Date: 8/2/2004
> Time: 6:44:44 AM
> User: N/A
> Computer: DOMAIN
> Description:
found.
> Event Type: Error
> Event Source: NtFrs
> Event ID: 13568
> Date: 8/2/2004
> Time: 6:45:49 AM
> User: N/A
> Computer: DOMAIN
> Description:
found.
> Event Source: NtFrs
> Event ID: 13501
> Date: 8/2/2004
> Time: 6:51:04 AM
> User: N/A
> Computer: DOMAIN
> Description:
found.
> event:
> > see
> > in JRNL_WRAP_ERROR.
> > journal.
> > long time.
> > the replica set.
> > unavailable.
> > as shown above.
> > 13501
Thank you very much Jill - I'll try and look up the KB. thanks again!
Michael
news:eUWAheAhEHA.2916@TK2MSFTNGP12.phx.gbl:
> Hi Michael,
> result, the text that normally appears in the FRS events you listed is
> missing and has been replaced with a standard message: "The
> found. The local computer may not have the necessary registry
> information or message DLL files to display messages from a remote
> computer. "
> can try to locate one in the morning unless you beat me to it.
> journal wrap and should be addressed if you have multiple DCs;
> however, it looks like you have only 1 DC so FRS isn't replicating
> SYSVOL (unless you are using FRS with DFS).
I found a KB that talks about the AUXSOURCE flag that the event text is
referring to:
Detailed Usage of the Event Viewer /AUXSOURCE Switch Option ID: 312216 at
http://support.microsoft.com/default.aspx?scid=kb;en-us;312216
This might explain why you are seeing the "placeholder" event messages
instead of the real event messages.
news:8_iUc.3648$de4.3053@trndny07...
> Michael
> > Hi Michael,
> > computer. "
Thanks for all your help Jill! I was able to solve the problem this
morning:
After I performed a chkdsk to fix errors, chkdsk truncated the bad USN
Journal entries. Then upon logging on, the event viewer log entries gave
detailed descriptions showing a Journal Wrap, SYSVOL errors, etc. instead
of the "AUXSOURCE" ones. I then performed a Journal Wrap Restore by
editing the registry (I had to add the DWORD entry, set it to 1 (I reset
it to 0 after the restore), did a net stop ntfrs and then a net start
ntfrs, after which the SYSVOL was recreated and the Journal Wrap fixed. I
now have no bad entries in my FRS log and everything appears to be
running fine. Again, thanks!
Michael
news:e87WHuHhEHA.2784@TK2MSFTNGP09.phx.gbl:
> referring to:
at
