Question Need help! Random freezing!
Aug 27, 2019
I pull my reliablity report and all it says is hardware failure 4 times in a row but does not actually tell what is failing? Is there anyone who could give me some help here?
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 117
Parameter 1: ffffdc8507bf3010
Parameter 2: fffff8054cbf3934
Parameter 3: 0
Parameter 4: 0
OS version: 10_0_18362
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.18362.2.0.0.256.48
Locale ID: 1033
Description
Problem signature
Code: 141
Parameter 1: ffffdc84f6424050
Parameter 3: 0
Parameter 4: 15d4
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Description
Problem signature
Code: 141
Parameter 1: ffffdc84fa737460
Parameter 3: 0
Parameter 4: 15d4
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Description
Problem signature
Code: 141
Parameter 1: ffffdc8507c11010
Parameter 3: 0
Parameter 4: 1ff0
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Aug 27, 2019
Gigabyte Z390 motherboard
Intel i5 9600k
Corsair Vengeance LPX (32 gb @ 3000)
RTX 2070 Super (nvidia founders edition)
Corsair CX 750 PSU
1 WD blue 500gb SSD
1 WD blue 1tb SSD
1 Seagate Iron Wolf 4tb
Intel i5 9600k
Corsair CX 750 PSU
1 WD blue 500gb SSD
1 WD blue 1tb SSD
A quick guess is one of your HDD's is starting to fail, likely the oldest. Try downloading and running a program called "Hard Disk Sentinel" to check the health of your drives.
Aug 27, 2019
They are all brand new, less than 2 months old but I will download it and see what happens. Will post the results as soon as I get them! Thanks!
Aug 27, 2019
There was a USB device that had the yellow warning symbol no idea what because it just said USB input device though. I feel like I checked that when all of this started the other day and there was nothing there but possibly I missed it? Either way I deleted it and will see what happens. Will keep you updated, thank you for all of the help so far!
Aug 27, 2019
Still no luck, crashed 2 more times with the following reports in reliability
Description
Problem signature
Code: 141
Parameter 1: ffffc9820e924050
Parameter 2: fffff8072ab75934
Parameter 3: 0
Parameter 4: 27a4
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Description
Problem signature
Code: 141
Parameter 1: ffffc9821cb54460
Parameter 3: 0
Parameter 4: 0
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Aug 27, 2019
No luck, just happened again
Description
Problem signature
Code: 141
Parameter 1: ffffbd0e0667c460
Parameter 2: fffff80659ba4534
Parameter 3: 0
Parameter 4: 658
Service Pack: 0_0
Product: 256_1
Locale ID: 1033
Aug 27, 2019
SFC did find some files and it has claimed to corrected them. I restarted and ran again this time with no errors. Also running malwarebytes and superantispyware as we speak. So far nothing is coming up there though. If this doesn't work then I guess I am reinstalling windows.
Feb 24, 2020
20
Did reinstalling windows end up working for you? I seem to be having the same issue, and to my surprise, can't find any major issues that pop out at me.
