G GloatsWithGoats Reputable Feb 2, 2016 1 0 4,510 Feb 2, 2016 #1 My C partition on my HDD is at 324gb but only 31gbs are being used. i cant re size it in disk management. I'm trying to decrease the size of this partition to Mirror the whole thing to a new ssd that i got. Help!!
Solution popatim Feb 2, 2016 The cloning software should have no problems doing that automatically. Which ssd did you get?
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Feb 2, 2016 Solution #2 The cloning software should have no problems doing that automatically. Which ssd did you get? Upvote 0 Downvote Solution
D_Know_WD Judicious Jul 30, 2014 6,630 3 35,960 Feb 3, 2016 #3 Hi there GloatsWithGoats, I would agree with popatim. Alternatively, I guess you can use some third party partition manager tool: http://www.tomshardware.co.uk/forum/51389-63-good-free-disk-partition-software Cheers, D_Know_WD Upvote 0 Downvote
