S Sharpy963 Honorable Aug 17, 2013 24 0 10,510 Aug 19, 2013 #1 My computer keeps crashing and restarting and i need help reading the .dmp files, i have 15 of them in the minidump folder, if there's a way i can maybe upload one in this thread and someone read it and tell me what the problem is?
Solution popatim Aug 19, 2013 Use the Dump Check Utility (Dumpchk.exe) to read a memory dump file if you are running win7 you will need the debugging tools http://msdn.microsoft.com/en-us/windows/hardware/gg463009.aspx
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Aug 19, 2013 Solution #2 Use the Dump Check Utility (Dumpchk.exe) to read a memory dump file if you are running win7 you will need the debugging tools http://msdn.microsoft.com/en-us/windows/hardware/gg463009.aspx Upvote 0 Downvote Solution
