I need a 3-pin fan splitter but I'm confused between 3-pin female to 2x3-pin male and molex to 2x3-pin splitter. So please suggest which one should I go for. Peace.....!!!!!!!
What case and where do you plan to connect it? Are you going to use a motherboard header to run multiple fans, or do you want to drive them directly from the PSU via a Molex connector?
Your fans have female sockets and the motherboard header is a male plug.
I'm going to connect 2x120mm fans(1 for intake and the other is for out-take). I want to which will be best? Should connect it to motherboard or directly from PSU? As I'm going to use a splitter so which one is going to handle the pressure well?
There is a four pin SYS-FAN header on the board beside the main 24 pin power connector, right next to the CMOS battery. That is where I would plug into. If you have four wire fans, the motherboard can use PWM to control their speed.
