I need a 3-pin fan splitter but I'm confused between 3-pin female to 2x3-pin male and molex to 2x3-pin splitter. So please suggest which one should I go for.
I'm going to connect 2x120mm fans(1 for intake and the other is for out-take). I want to which will be best? Should connect it to motherboard or directly from PSU? As I'm going to use a splitter so which one is going to handle the pressure well?
