Question Need help regarding CM K281 Case and CM Hyper 212x Cooler compatibility with x570 motherboard and 5800x
Avik_b123
78
In my current rig, I have the Cooler Master K281 case and Hyper 212X CPU cooler. Now I want to upgrade to the 5800x and an x570 motherboard. WIll the case and the CPU cooler support these?
P.S. Both of the CM items were bought back in early 2013.
Thanks in advance. Peace!
kanewolf
The problem will be that you probably don't have the correct AM4 mounting hardware for your cooler.
The case/cooler combo will still fit together. Changing motherboard/CPU won't change the height significantly.
You WILL want to do a clean Windows install when you change motherboards.
